Plug the power adapter into mains supply wall socket and the other end into control unit.
You should see following LED sequence:
1. Plug in power adapter: steady yellow light for approximately 60 sec.
2. Steady blue light (after short purple and yellow light): Linux OS is loading
3. Blue light blinking: Java application is loading
4. Zipabox getting ready: slowly flashing green light
5. Zipabox ready: steady green light
Zipabox - Powering Up
Is this article helpful?
