If you have a lot of metal in the exterior construction of your home, this could significantly impede wireless communication. Metal is an insulator of radio signals. If your house has metal siding or a stucco finish over a metal mesh, you may have range problems on devices outside your home communicating with the Zipato Controller inside.
Related FAQs
- Registration of Zipato Controller
- How to clear (unregister) a Zipato Controller?
- How to do a Factory Reset on a Zipato Controller?
- I got "Validation time expired" message, what to do?
- I got "Allowed registration time elapsed" message, what to do?
- I got "Failed to add new box" message, what to do?
- My Zipato controller is Offline, what to do?
- Signal interference problems on Zipato Controller
- Zipabox - Powering Up
- Zipabox - Waiting for more than a 5 minutes and still there is no steady green LED light indication
- Zipabox - LED indications
- Zipabox - Hard reset procedure
- How to upgrade or downgrade the firmware version on Zipato controller
- How to remove Wall holder from the ZipaTile
Properties
Author
Guest
