CO2 sensor
pm03 shared this question 13 years ago
Are there any co2 sensor compatible with the zipabox? Are you planning to support one?
Thanks,
Philippe
Replies (10)
Where can i buy it?
No, I was asking for a co2 sensor, not a co sensor...
In this case, I don't know:-(
I'm just curious, what will you use the co2 for?
Check out netatmo.com
Rein: I guess to see the "freshness" of air in your home.
Yes, to check the freshness of air. I'm thinking of activating an air extractor when it reaches a high level (which means not enough oxygen in the room, that's typically the case in the bedroom in the morning).
I know about netatmo but I don't want to add another system...
I saw it, but would it work with a zipabox? The device is not listed as compatible.
