programming
Grégory Lemoine shared this idea 12 years ago
Is possible Rule in commande line ?
hello,
I installed my new zpiabox with the KNX interface to manage my home automation Tébis HAGER under ETS4.
I can not seem to make a lighting control from the application zipato.
However I have the status of my return when lamp on or off.
I programmed my BAOS 1 item on the 0/0/8 group (corresponding to the ON / OFF control output 1 of my Hager module) and my 2 BAOS object on the 0/0/9 group (corresponding to the status of my output HAGER 1 module).
I am inspired by the documentation Domadoo http://blog.domadoo.fr/2013/06/14/guide-dinstallation-du-module-knx-pour-la-zipabox/ but it does not work.
Thank you for your help.
Kind regards.
Tony.P
Inspiration is not sufficient if you wish to be successful in programming. A lot depends on your knowledge and experience but in your particular case you seem to lack some of them, even though it's primarily Zipato's fault. However you can achieve a different result with the help of programming tutors online from https://assignmentcore.com/programming-tutor/, who will demonstrate on their own example, how coding should look like. Learning few tricks will make your lightning control work as expected.
