1clic, 2 clic, 3 clic scenarios
matthieu shared this question 13 years ago
Hi All,
i saw in fibaro module : FGK-101.
Parameter no. 14 : Scene activation functionality.
Default value: 0
Available parameter settings:0 - functionality deactivated 1 - functionality activated
The device offers the possibility of sending commands compatible with Command class scene activation. Information is sent to devices assigned to association group no. 3
Controllers such as the Home Center 2 are able to interpret such commands and based on these commands activate scenes, to which specific scene IDs have been assigned.
The user may expand the functionality of a button connected to IN input by distinguishing the sequence of it being pushed. For example: double click would trigger the “goodnight” scene and triple click would trigger the “morning” scene.
To fully use the possibilities offered by the parameter no.14 it is recommended to use a momentary or a toggle switch (parameter no.3).
Scene ID is determined in the following manner:
IN input:Switch from “off” to “on”
ID10 Switch from “on” to “off”
ID11Remaining IDs are recognized correctly if the value of parameter no.3 was set to 2Holding down ID12 Releasing
ID13Double click
ID14 triple clic
Do someone already use this features with zipabox ? i know that the fibaro box can do it.If yes, how to do it :)Best regards,Matthieu
