Technical Documentation
Steven Starks shared this question 13 years ago
Hi, Do we have a technical documentation? where can i find in the internet? thanks
There is an online help in each widget (marked by "?"), explaining how particular functionality should be used. For now, we published help for "security widget", "camera widget" and "climate widget". We are working on "rule creator" online help which is very demanding as rule creator is practically programming language with almost unlimited set of options. We are open for any suggestions in this area...
Replies (14)
7
I think, as a start, then some examples of different kinds of rules would be a great help.
+1
It would be nice if there will be a good manual soon, because I want to use my Zipabox for my central heating.
It must be possible for my family to warm-up every room separately.
I bought several Danfoss valves, a Horstman Thermostat and Horstman switch, but until now I was not able to install it properly.
Before buying a zipabox i would like to see the manual and see the way things work. I now own a vera light and i am looking for an other box, because i can't programm/don't understand Luup.
It would be nice to know how and what the Zipabox works
I too would like to see a PDF manual prior to buying
is it possible to repost this guide, only since the group and scenes (which I very much need) are not working.
A guideline will be good. Specially for the rule.
Have a nice day.
3
I already requested a wiki where the community can share rules and solutions.
5
For me it is very important to have a mode debugging for rules.
I have actually a problem with a rule : i have the differents state in the events log, but the rule doesn't work.
I don't know if the rule treat correctly the differents state of the endpoint, or, i think, as there is a lot of type of virtual sensor (in the device manager) like : http device, virtual, generic .... then I sure that the rule don't understand the real state.
ANSWERED?? And where is the manual? Also e technical manual tha explains how to use the rules creator and the meaning and use of variables, functions and so on (for example the use of NOW, Time of, or betewwen etc.)?
Where to find details about the new implementation, like static IP or Cloud or other similar thing? Wgere is explain how to use them?
Many thanks.
I also have great need for this manual so a link pleas
Best Regards
Anybody knows if the "Micro Module Switch Double" can be used in 3way and 4way wired connections?
