Doorbird d101s add failed
Jozef Humaj - Fixni.to shared this problem 7 years ago
Hi, i can not add Doorbird D101s.
actually, found the solution. In the new doorbird settings, under administration login in the doorbird app, you will see Doorbird Connect ONVIF, unchecked. You need to check this, then it becomes discoverable.
actually still cant save it though get the message "failed to save device"
edit: did a page resfresh and the doorbird was there. Had to go to the settings and add the login details and port again. Sync and save., page resfresh and all good.
Is the zipato on the same network? I had no problems adding the dooebird
yes it is. I have no problem using it with app too. What number have you passed in "port" column ?
I have left the port on discovery empty. When I go to the settings, I can see that the port is populated at value 80. Also, the camera settings needs to be completed as upon opening the camera settings the user name and password will need adding.
No nothing, i tried to left port blank and set it to 80 too, but no change at all. I'm goint to open a ticket
bugger
Thanks Adrian for your solution, it works like a charm :)
Actually on the same admin page there is a schedule. Here i have enabled all for puah and also for http calls. Im not sure if the http calls do something but maybe this also needs to be fully enabled.i can imagine that if you dont enable http calls the doorbird will simply not utilize it.
