Rule Creator
Brandon Connor shared this question 8 years ago
Dear Zipato-Team,
I am in vain to create a rule to control severel RGBW bulbs at the same time.
For example: I would like to set the first (main) bulb to intesity 60 % and blue color. The other bulbs in the same room should set the equal values.
Can you help me to create a rule for this?
kind regards
Brandon Connor
If you always want the same settings I recommend creating a scene insted, it's a lot easyer and cleaner.
If you want a variable version. You'll need to add a virtual level controll. And create a rule similar to this, you can add more lamps below the first one. Also add a trigger for the when block. Name it save, sync, profit.
/bfcae4e5b7277ac56dfbb0b3ac6369b5
If you want to set rgb you'll need to add a level control for each color. And set the color insted of the brightness.
