List of Oregon compatible devices
Olivier Guihard shared this question 13 years ago
The new RF433 module being available, I'd like before ordering to make sure that it will be compatible with Oregon THWR800 sensor! It doesn't appear in the list displayed on "add device" menu, does it mean " non compatible" or non tested? I see in the list other Oregon sensors which are based on the same protocol than THWR800 ( THGR810 ).
It's compatible, but it hasn't been tested yet.
May or may not work.
Will be tested in our next Oregon batch (after the summer).
Hi there
Unfortunately the last release forgot the THWR800.. It's a real pity as this temperature sensor seems to be the only one available to measure swimming-pool temp. A real must-have for people wanting to monitor their swimming-pool.
I asked a dealer to test association, thinking about "same protocol, it should run even with a false module naming": did not succeed.
When will you propose this module?
Best Regards
Olivier, look here:
http://blog.domadoo.fr/2013/10/23/guide-dinstallation-dune-sonde-thgr122nx-avec-la-zipabox/
It says:
(bientôt supportée) > Soon supported
Thank you! Waiting for zipato confirmation then
Hi Zipato, any news?
