Getting Fibaro FGR221 Roller Shutter position
Alain shared this question 13 years ago
I try to make a rule which use the position of the roller (sending a mail if wind >30kmh AND the Roller Blind >20% open).
I can get a sensor for the FGR221 endpoint (like a Dimmer), but it indicate "No Attributes"...
Is this a trick to be able to read Roller position, or is it a bug ?
Thanks in advance for your answer.
Alain
Please remove then add your fgr221 to your Zipabox. After that, you should see a "position" parameter for the dimmer endpoint in the rule creator.
Hi Marko,
Thank you. It works now. I just re-apply device descriptor and it is also OK.
