Security module
Benoit D-F (fr) shared this question 13 years ago
Hi Zipato,
Can you tell us more about Sécurity module ?
What will he do ?
When will it be available ? ...
It will support 6 wired zones, wired siren, SLA battery, and one programmable output.
It will also have one USB port (for connecting 3G stick or other) and one serial port (selectable RS-232 or RS-485).
Thank you for your answer.
The "backup module" will be useless after...
What will we do with the "backup module" after...
Also if i understand well, the new security module, is the same as the backup module with additionnals functions and connectors (6 inputs/1 PGM output / 1 siren output). Battery, Usb and serial port (just selectable is new) are the same ?
Is it right ?
No, the security module will not have a battery. You will have the possibility to attach a sealed lead acid battery to it, like you would to an alarm panel.
OK thanks for answer but otherwise appart the battery, it would be the same functions ?
