Sort Lights & Power
Guest shared this idea 13 years ago
At this time it is hard to find an component in the list of lights & Power. They are all in the list in a "randomized" order. Random is from my point of view ;).
Can you explain how they are sorted please? It may helps to find the components.
Would it be possible to let each user the possibility to sort them in its own choice, you could add a new field "order" or "priority" ("ordre", "priorité" or "tri" in french)? Or may be to choose to order them by room, by type,... and may be by default alphabetically?!?
For the time being, it is always sorted alphabetically. It is possible to rearrange the list using drag and drop but there is no possibility to save the change for the next session. For me, it is easier to order the lights from left to right in the living room and put other switches at the bottom of the list.
