Z-wave antenna replacement
Stephane shared this question 13 years ago
When moving my box, I broke the z-wave antenna, which is now attached with a piece of tape, and somehow jeopardizing z-wave netwrok range...
Question is : can we obtain Zipato spare parts somewhere ?
Or can I just replace it with a SMA 868MHZ antenna from any supplier ?
Any experience on this ?
Thanks !
Stephane
Please contact your supplier for replacement.
And yes, you can use any antenna for 868.4 MHz with the right connector.
Working flawlessly with a 2.4 GHz 20dBi wifi SRP-SMA antenna found on ebay
For that matter, it will work with any piece of wire, or even without the antenna (on a short range).
BUT to get the proper range, please use the correct antenna for the frequency range.
Thank you Tomislav for your answer and Thomas for sharing your experience.
Stéphane
