Control outputs separate on Fibaro RGBW
Fredrik Ahnell shared this problem 8 years ago
I use the Fibaro RGBW to control my water heated floor and have been doing that for some time. But after a power failure I had to reset the Fibaro RGBW to be able to connect to it again. My problem now is that I can’t controlled the outputs separate as I did before.
I can’t remember that I needed to change any parameters before, I just added the colors to show as a device, but when I do that now I can not change the value on it.
f66b42a15b218bbf6a7abaacd1b952d4
7713c671e1b2064e39332856c7aaf699
I see it in my device browser, but can not change the output level.
This is a picture how i had it in my device broswer before reset.
OasA0xr
Anyone that can guide me on what I'm doing wrong?
Answer from support that solved the problem!
please try upgrading to Beta firmware and then adding the device again. This time do not name it at the end of process, but rename it afterwards.
Please contact us again if the problem persists.
Borna
I found a old image of the structure in device manager. And it looked very different before I reset the device?
As my image in my question shows that all colors are now under Color control, before they where separate directly under main group.
b7d8555fe3a4c42f3ac83a8396a83afa
Borna
