How to remove 433 devices?
Jeroen Millenaar shared this problem 13 years ago
Not a Problem
It seems not to be possible to remove 433 devices. When I select the option remove device, the only option I have is to start the z-wave removal process.
Option REMOVE DEVICE should only been used for the removal of the Z-WAVE devices. For all other devices you should go to DEVICE MANAGER > RIGHT CLICK ON THE DEVICE and select DELETE
Just go to Modules and right click on the item you want to remove.
Because there is no information stored in de 433 device, you dont need an exclude proces or something like that.
sorry Anjos, didn't see your reply before:-(
