Rule creater with sunrise
Tommy Fehrm shared this question 8 years ago
I have had a rule that lightning up a lot of lamps every morning with sunrise + 3 hours. The last week this set up has failed every morning. Is there an app in Zipato who gets the information or what is the possible caus to my sudden failure?
check your virtual weatherstation and see when it was updated last. As Zipato use Weatherunderground and community based weather station system, you may find your particular station has gone offline. Try another local area if so.
OK but how do i change station, when i tap on wather symbol on frontpage there is only readable information? Or is there a setup some where?
You can create a rule to update manually the virtual station, you need to go the API / Meteo / attributes / values, you can trigger this rule every day by using an HTTP puzzle with GET and the URL shown.
Thats interesting, thanks Alberto.
