Fibaro Dimmer 2
Tommy Fehrm shared this question 8 years ago
My dimmer turns off automaticly only when it's dimmed, not on full level. The effect is less than 80W. I can have all lamps in 100% level in hours but as soon as i dim, it turns off. I have installed a bypass 2 but it doen't help. Solution?
Have you tried to calibrate the dimmer? Look up Fibaro manual how to do it.
Have done it, still doesn’t work
is your lights circuit dimmable?
yes trail mode
Read paramater 32. If this is set to 1 dimming is not possible.
Write 0 to this parameter.
32. On/Off mode
This mode is necessary while connecting non-dimmable light sources. Setting this parameter to 1 automatically ignores brightening/ dimming time settings. Forced auto-calibration will set this parameter’s value to 2. Available settings: 0 - on/off mode disabled (dimming is possible) 1 - on/off mode enabled (dimming is not possible) 2 - mode selected automatically
https://manuals.fibaro.com/content/manuals/en/FGD-212/FGD-212-EN-T-v1.3.pdf
Great, it's working now...the 32 was set into automatic and when i changed it to disabled and pos30 automatic to forced trailing everything started to work. Thanks again!
