Timer
Antonio Palumbo shared this idea 13 years ago
How i can make a rule where after 2 hours from when i put witch on it changes to off?
brgds
Replies (6)
When switch is on, join, wait 7200, switch off.
so simple...thank you
The reason for the join is to isolate to initial on state or the timer will start over if you manually change the state within 7200s
is not possible to use a variable to choose the duration of the wait time?
brgds
Why do u want to use a variable? (to make it random)?
i want to choose every time how long is the wait time...
