Intelligent Scene
Guest shared this idea 13 years ago
It could be nice to be able to add "intelligent" scene for example: If it is ~5pm then I open the roller shutter at 50% otherwise I open it at 20%. At this time it is possible to create many scene and decide to run the scene by an intelligent rule!. But if i decide to run manually a scene I need to be intelligent :) and to choose the right scene or to declare a virtual switch. So the solutions exists but are complicated and zipato designed a box to be simple ;). So do you think about it?
If you start adding inteligance to the scenes, you will finish by creating a "rule creator";-)
Scenes are just a groups of states.
:) It is possible
