Creating a luminance rule with a 4in1 multisensor
What rule do I use to make light turn off/on using luminance metre on the 4in1 multisensor?
I guess something like this:
when (luminance > -1) <------------- i.e., rule is triggered by any valid value in the sensor if (luminance < 2) Switch light on else Switch light offThe rule will be triggered every time the luminance value changes. If the switch is already in the right state, nothing will happen. You may want to turn the light on for higher lux values, say anything under 5, or even 10...
Is this correct? Is itsnt working for me.
Yea I guess makes sense. Any chance you could create the rule and send photo? Thanks
Liam,
I would do something like the attached rule, Zipato Quad shows luminance values on % not LUX. JOIN puzzle is to make the rule restart (or be triggered again) in case the sensor updates values to Zipato controller. In my case 1-3 % is more or less sunrise/sunset window.
Liam,
