Error Message when I create a rule
JC shared this problem 13 years ago
Not a Problem
When I create a simple rule "When/Action" and I try to save it, I have the follow error message :
"rule2java: java.lang.IllegalStateException: Not a JSON Object: "
The rule is : When it's time "20h30" put the light ON
I use KNX object.
Make it like this:
When Scheduler (select time and day)
Lamp action = On
I tried to setup the rule like your adive (I hope :o) ) but I have the same message...
When "Date variable" to DD/MM/YYYY between DD/MM/YYYY and Time "20H30" (I think that you would say when you talk about "Scheduler")
Lamp Action "ON"
Error Message
Use it like this:
aj8HzCRD72ufRMmuDcKY
Don't use the date variable and time.
thank you for the screenshot....
No problem...have fun!
