Play a rule if scenario played
JC shared this question 13 years ago
I want to know if I can play a rule when I played a scenario.
example : I want to put on the lamp at 20H30 if the scenario "shutters down" played at mornning
Can you explain me how to do it ?
U can do this with a virtual switch or with a variable. Make an rule... when u turns on the lamp then set the virtual on.
Then an rule... that checks the virtual switch and then runs a scenario.
Hallo, to perform rule only when is switch on scenario, the rule shall be disabled in "My home rule"?
wrong question, I solved.
Thank you for your clear and detailed explanation of the situation.
