Does the Zipabox support command class scene activation?
Jan Vanrossen shared this question 13 years ago
I was wondering if the Zipabox supports the command class scene activation feature of the Fibaro Door-Window sensor. When an external switch is attached to the sensor, this should allow the Zipabox to determine how many times the switch was pushed and activate a scene accordingly. For example: press once activates good morning scene, press twice activates movie scene, press three times activates good night scene, and so on. The functionality is decribed in the Fibaro Door-Window sensor manual (parameter no. 14).
Thanks for your response.
I've the same question. Nobody tried this?
