Can the manual switch on a micro module be set to trigger a scene defined in my controller?
Jan Vanrossen shared this question 13 years ago
Hello, when using the manual switch on a dimmer module, could this be set to trigger the activation of another z-wave device in my network or couldthis activate a scene for example?
Which dimmer module are we talking about?
Fibaro dimmer for example
Yes, this is possible.
Here's an example.
1) Create a virtual switch.
2) Connect a momentary (bistable should also work) switch to dimmer terminals S1 and Sx
3)
Create the following rule.
DyEK00Dfpytrbj6ZyC1k
The virtual switch should change state each time the momentary button is in ON position.
