Chacon 54795
xmeslin shared this question 13 years ago
Do you support Chacon 54795
http://www.chacon.be/index.php/domotique/confort/kit-3-prises-telecommandees-dio-first.html
It seems pretty similar to 54785 CAYCR-3500 (http://www.chacon.be/index.php/catalogsearch/result/?q=54785) but cheaper :)
Tks,
Xavier
Replies (11)
Haven't tested that particular device, but it should work .
ok I will try it
tks
Hi Xavier,
I have those modules. They work pretty well, also for the remote. But for the remote when you associate it, there will be 16 buttons. You will have to find those who are working (6/16 for the remote of this device).
Salut Xavier
Je possède ce kit de 3 prises et 1 télécommande. Ca fonctionne bien avec la zipato. Pour la télécommande quand tu vas l'associer tu auras 16 boutons. Il faut tester parmi lesquels les 6 sont opérationnels pour correspondre à ceux de ta télécommande.
Cordialement,
Fred
Bonjour,
Je n'ai pas compris de quelle façon tu effectues le couplage avec la télécommande.
La mienne n'a que que 6 boutons (elle ne pilote que 3 canaux).
Lorsque j'ai voulu le faire, j'ai perdu le couplage avec les prises commandées.
Pourrais-tu préciser la séquence des opérations?
Merci de ton aide.
Cdt
Michel
ha great. Tks. I will buy some this WE and try then.
Xavier
I bought the system and it doesn't work. Actually I can add a wall socket with the zipabox but when I change on/off, nothing happen and during association it doesn't blink as it does when I paired with the remote.
Second question, how do you associate the remote ?
Tks,
ok after some tries I finally get the remote working ok.
Still struggling on the wall plug but I thin I may have a zipato issue here.
Tks
ok everything works fine now.
Tks
When I first associated the device, don't know why it created me a device which not physically exist. Then re-did the association, found correctly the device. Just had to delete the device that wasn't exist.
Great to see you manage to have your device work fine.
Fred
it works so well I think I will buy another pack :)
For light management it's perfect. No big deal to not have the "acknowledge" protocol based. My eyes do the job.
Frederic P wrote:
Hi Xavier,
Salut Xavier
Cordialement,
Fred
Salut Fred
Je peine un peu a installer la télécommande chacon et un module émetteur. Comment procède t on exactement pour l'association ? car ca a l air de marcher mais je n 'ai pas de retour quand j'actionne la télécommande ou l'émetteur ?
Olivier
Bon je réponds tout seul. Il faut associer obligatoirement le bouton a un interrupteur pour voir un événement sinon rien ne se passe.
Olivier
