An editor to use the API
Guest shared this idea 12 years ago
It could be nice to have an editor to use the API, integrated into the web-interface and where we can store pieces of programs (with syntax coloration and code completion) directly integrated to the zipabox (without authentification). The risk would be to have bad programs that "kill" the zipabox!. I do not know which language programmation should be available ? (LUA may be because it is used by some others box, so you can easily get new users :) )
Then it could be nice to have a kind of cronjob or/and an event listenerAnd finally you would be able to have an app store where users would be able to share them codes :).
Wow...the "app/code/rule store" idea is just great ;)
+1 for LUA !
Actually I am using Python with Zipabox API and it works fine on a raspberry pi. It is easy to write quickly something. There are a lot of information on internet
