Right way to replace the batterij of the Fibaro doorsensor...
Hi Zipato,
i see that my battery of the Fibaro Doorsensor is running low. Can u tell me what the best way is to replace them?
Last time i tried i had to remove and readd it to make it work again. (this device is a pain in the %$#@ to add)
Thanks!
As far as I remember, you have to open your door (keep it open), change the battery then close your door. Otherwise if your keep the door, it will reset the sensor.
Hi Thomas,
Thanks going to try it.
Hi Thomas,
Wait!
In fact I found this and I am not really sure about how to do:
1) Take off the Sensor's cover and remove battery. Make sure the TMP button is intact.2) Touch the Sensor's body with a magnet,3) Insert the battery,4) Remove the magnet from the Sensor's body, 5) Remove the battery6) Re-install the battery,7) Reset will be confirmed by double LED blink.
What do you think?
Wait!
What do you think?
i dont know :) But sounds more like a reset then battery change.
Yep it is
So I suppose changing the battery while keeping the door open is the right way.
Yep it is
