Seting a thermostat temperature doesn't update the climat widget
Gilles shared this problem 11 years ago
Not a Problem
I made a rules that et temperature to a fixed temp. when conditions needs. It works but the climat widget is not updated with this temp. and is showing the programmed temp. and not the last temp. my rule sent to thermostat
Ok, i fund the solution. It was not a problem...
We need to take the thermostat trigger in rules not the temperature set trigger...Sorry
