Fibaro doorsensor cannot be removed?
Not a Problem
I have a Fibaro door sensor (incl temp) and I had an issue with the battery replacement.
It stayed offline and after a while I did a series of excluding and including.
Excluding didn't work: it saw the module and said it was excluded but it stayed in the interface.
Finally the inclusion worked and the door and temp sensor appeared... as an additional one!
The old one is still there and I cant get rid of it!
Anyone know what to do to remove it?
Dashboard >> Total devices >> Go to device (top level) >> Right button >> Delete
solved it!
was on mij gf's macbook without right mouse button...
Thanks!!
solved it!
Thanks!!
Only a little question: everytime I need a battery replacement, It's needed to delete and add the device again???
So if I have one or more rules with the device, I have to rewrite that too? :-?
No you don't need to remove/delete it again. Just open the door then replace te battery and close the door again.
I think it's the same for other battery operated devices.
