What is the best energy meter device supported by Zipabox?
Guest shared this question 13 years ago
I'd like to add an energy meter maybe either on Meter or on single plug? What do you suggest?
i try aeon labs energy meater with clamps and the measures are not correct.
Zipato's staff tell me that they are working to resolve the problem.
I get a wrong computation of the total consumption (much more greater then the real) even if I didn't unplug the meter (it is connected with the usb power supply).
I noticed several missing event during the night: could it be for that?
Anyway, it is not a good way if I have to remove the meter every time the problem occurs.
Is there any way to reset meters value? Or to reset the CUMULATIVE_CONSUMPTION counter?
Best option would be a meter (z wave supported and zipato supported) that connects using a P1 connection (smart meter needed) since all other solution like clamps and pulse meters are not accurate.
Is the Zipato power module not that accurate then?
