Light not turning on/off
I have 3 simple rules:
1 turn on light at 19.25 all days
2 turn off light at 23.30 on mon,tue,wed,thir,sun
3 tung off light at 0.15 sat, sun
Very often the light is not turned on/off. The strange thing is, that the controller doesn't write anything in the event window when this happens, so I don't think the rules are executed. But I can't see any pattern in when it happens.
Hello,I've gone through some issues few days ago with the rules.You can look at all your previous rules in order to verify if you don't have an "unknow" device within one of them. I got the same problem.Also, please try to disable all your rules and activate them one rule per one, in order to find which rule is faulty.
I only have these 3 rules. And they fail at random.
Maybe it is because of bad wireless connection to the plugin module, that controls the light - but in that case I don't understand why I can't see any activity in the event window.
