Support for Secure SCS317 ?
DaBoss shared this question 11 years ago
Does zipabox support Last secure scs317 ?
If not, does zipato work on It ?
when it will be supported ?
Replies (13)
Support will be added as soon as we receive our SCS317 samples.
Any news?
Any news on this?
I am about to buy a Secure scs317. I really need to know if it will work with the zipabox.
Thanks in advance.
Up!
Any news on this?
Thanks.
Greetings,
Initial support for the SCS317 is complete.
Please note that this device somewhat conflicts with the climate widget since they are both advanced schedulers.
Hello Marko,
Shouldn't it be written on the changelog? Which firmware has the support?
Thanks.
No, the changelog usually doesn't contain information on newly supported devices.
SCS317 will work with the current firmware.
Hi, when we tested this device a couple of months ago, it seemed not well supported (v0.0.998). How is it now ?
Greetings,
What issues did you encounter with the SCS317 during your tests?
Tests were done by a former colleague. I’ve tested again the Secure SCS317.
When I change the temp instruction on the Zipabox, the device gets it after manually sending a NIF (by the way, default wake-up is 1440 min !), so that’s OK.
The issue is that the Zipabox doesn’t get the overridden temp instruction from the device : if I change the temp instruction on the device, it doesn’t change in the Zipabox. That works with the SRT321 though.
Any news on this? I have the same issue...
Hello!!!! any news???
