How i can use mi-light or lighteu-bulbs or LED?
Stefan Hack shared this question 7 years ago
Hello, dear community,
can somebody tell me please, how can I use the lights of mi-light or lighteu with the Zipabox?
I hope, there is up to now a way for it.
Thank you for a tip and many greetings
Stefan
you can send UDP calls to your mi-light. You have to translate the hex calls from milight (see their manual) into ASCII. This makes some limitations. You can turn on and off your lamps and also some (but not all) colors, because the code in HEX is not available in ASCII. Perhaps sometime it is possible to send UDP commands with hex figures.
See here:
https://community.zipato.com/topic/hex-hexadecimal-for-udp-socket-only-utf8-now-wifi-bulbs-control-as-philips-hue
