All rules with scheduler doesn't work anymore!
Is it the same for you?
In my case all rules based on a scheduler doesn't work.
So, If a rule run a scene at 18:00, nothing happens!
I need support urgently!
Regards,
#William
I have problem with my rules (based on scheduler). Today i change the hour and synchronise, the feedback of synchronize is ok but when i refresh the dasboard , the date of synchronisation is always the old date !! and now the rules doesn t work.
Please help !!!
Please help !!!
@ William >> does the sync work?
@Christophe >> Disable all your rules and then do a sync. If this works then turn on 1 rule and sync again. If everthing still works then another rule on ...etc To see where the problem is.
I have the same problem with me. It seems to me that occurred since the last update 0.9.988.
It do not work since the last update 0.9.988 . When i synchronise and refresh the dasboard it's always the same date (an old date !!!) and i have no feedback of all my device !!
tonight rules are ok but no feedback of all my device and date of synchronise always NOK
