simple Rule creation
Alessandro Spagnolo shared this question 12 years ago
i'd like to set that when the thermometer arrive to a set temperature it will comand the switch ON, once decreased it turn back off..i'm sure how to do, becouse the components doesn't fit inside the condition..thanks!!
Make it like this:
PH8fEzUTzXs43AY8n4Fm
You can also use the < (lower) or > (higher).
Can you explosion the first operator after when !=0 what does it check?
really thanks!!
now it works correctly!!!
