timer widget for detailled switch planning
I would like to have a timer widget. Similar to the planning slide in the climat widget.
The use would be to make a detailled planning (hour, day, week) for switches. This is difficult to realize with the rule editor.
I tried to use the climate widget, but it does not work without input (thermometer)
My idea is to use a scheduler to control a electrical heating with included thermostat. So I do not have an input for the classic climat widget. The output is only on/off for the radiator (with french system of "fil pilote"). I do not want to regule the temperature, this would be set fixed on the radiator by hardware switch.
I know that this is possible with the rules, but if I have several several opening and closing times, it gets difficult.
hello,
for me it is not possible to create a thermostat without thermometer. see attached pic 299. I do not want to have an thermostat but only to use the agenda function of this widged to define easier the scheduler configuration (in the rules).
see example in pic 301.
hello,
I would like to do the same... Sebastian, how can we use the thermo/climate widget without a thermometer??? Rgds, Frankie666
Making such a widget with pussle would be a pain!
