Zipabox offline
charriernicolas shared this idea 12 years ago
New zipabox, always offline.
Wath's appends.
thanks
Replies (6)
Do you see the green light blinking or steady? If blinking, this means that Zipabox doesn't have an Internet connection with the cloud. Please check you internet connection including the cable which you are using.
Led is steady green
But shall web open port on routeur?
In case you are using firewall, you should open TCP PORT 8080 and UDP PORT 9017
Nice i Willie check thaïs
Tanks
Hello
Open the TCP port 8080 and UDP port 9017
But always off line.
And les in steady green.
now it's OK
