Temp offset for Temperatur sensors
Frederic Haase shared this idea 12 years ago
it would be nice to have the possibility of configuring a Temperatur offset for Temperatur Meters.
For example one Temperatursensor of my FGBS321 reports 2 grad C to high, so it could be easy compensated and the dashboard shows what i want :-)
Replies (7)
I found this offset in the configuration of my temperatur sensor (Horstmann HRT4).
Some device have this in the config....The Fibaro Doorsensor doesn't have this.
By the way, did you try to offset the temp with fibaro flood sensor?
I can't get it working
Nope, not yet.
Good idea . . .
Got some off meter that's does not report the same value despite there at the same place.
The Fibaro HC2 has this for all temp sensors (i think) irrespective of whether it can also be set on the device itself
i dont get why easy developments like this is not done.
