Associating Devices Using Zipato Interface
Nick Halsey shared this question 12 years ago
I have seen with other controllers you can set-up associations between devices e.g. montion sensor directly connected to light switch. This will mean the response is much quicker. There are instructions on how to do this with other controllers but not Zipato see link below:
http://www.vesternet.com/resources/application-notes/apnt-19
Is this feature included? If not will it be included? and if so when?
At the device config you can do this.
Total devices >> Select device >> go to tab >> bindings
There is no tab for bindings? Any ideas?
What kind of device are you using?
The ones I trying to bind are Vitrum Dimmers:
Vitrum II BS Wireless (Z Wave) Dimmer
Vitrum II BS Wireless (Z Wave) (dimmer) Satellite
http://www.vitrum.com/sites/vitrum.com/files/sezione_download/01B040020_0.pdf
I have another post asking if they are supported as a previous post said they were but I have found this to be not quite true:
http://community.zipato.com/responses/are-vitrum-wireless-controls-supported
http://community.zipato.com/responses/vitrum
Just in case someone comes accross this post, I managed to set-up the bindings by using a battery remote controller set-up as a secondary controller. With this I was able to program the associations without using the Zipato interface.
