Widget security
ADENOT YANNICK shared this problem 12 years ago
I no longer have access to the widget security. after pin code, edit parameter security
the same : edit security settings to create alarm
Replies (7)
Did you try to refresh your browser? ctrl+f5
but you just need to open the security setting and press save
securityDevice.notFound
Please send me your credentials on hello@zipato.com
I'm facing exactly the same problem since today.
Could you fix it as soon as possible as I start to be upset by the lack of stability of the product. It's several days that I'm working on my domotic solution as I had several problems with different equipment.
