change modes of multiple climate widgets
Cantece shared this question 12 years ago
is it possible to change the mode of several climate widgets /thermostats collectively?
I want to change all thermostat from "confort" to "absent" together.
Thank you
You can create a rule within a rule creator.
Replies (6)
I think I have found the right action, but what is the value/variable to set the thermostat to "programme", "confort" or "absence"?
I have found this two actions:
for the first one it should be possible to ad a mode (heating, off, absence...) but I do not know ho to set the variable.
The second one is possible to write a value (8°C). I'm not sure how it works.
Please help.
I have found out how to reduce the temperature for all the thermostat widget in my house. It is not possible to put them all into "absence" mode, only reducing temperature.
It seems not to be possible to put them all back into "program" mode either.
Someone has a solution to link all the widgets together into one programm/absence order?
here is my rule for holidays.
On virtual switch (vacances) and 2 thermostats.
op this can help you.
