Fibaro RGBW Module no color setting via IOS APP
Slashroot shared this problem 11 years ago
Since 2 days it's impossible for me to change the color of my RGBW led strips using the iphone app.
The RGBW led strip can be powered on, but if you use the slider to change the color the "needle" will set itself back to the left (red part) and color will not change (white by default it stays).
I also noticed that i am not able to set colors full since i see a great amount of white light when using the web based RGB controller, i did not have this issue when using the slider in the mobile IOS app at the time it was still working.
Notes:
-Current firmware is 0.9.993 (installed at release date)
-Works when changing the colors via http://my.zipato.com
-If RGB(W) is set within a rule it will also work
-Have 2 RGBW controllers and both have same issue
-Zipabox has been reset to check if this solves the problem
-No firmware updates have been done just before this problem appeared.
Regards,
Maarten
After update to 0.9.994 is still have this issue on both my Fibaro RGBW modules
Also same issue with latest firmware 0.9.996
same problem...
