probleme with rf433 module on firmware 0.9.995
charriernicolas shared this problem 12 years ago
With new firmware 0.9.995, the remote control by chacon does not work even if i add it as a new device.
I have the same problème with oregon temperature, its only update when temperature change before temperature update every 45s
Can you help.
When i make en association, it's work perfectly, i this that the problem is during the use of the remote control in scene.
With new firmware 0.9.995, I can't use all my devices. I have these messagge:
Attribute: Preset Value:Today 493
Attribute:State Value:True
Attribute:State Value: False
Attribute:Today Value: 400
Attribute:Target Value: 31.1
I do not have now problem for temperature but with the chacon remote control, the problem is always here with firmware 0.9.996.
The blinding mode work but the remote control is not detected on rules.
When does this problem will be corrected?
Thanks.
