Virtual Meter not working
Gael Poffet shared this problem 12 years ago
I'm trying to add a virtual meter. I can create it but when I try to save my configuration I got the following error: "Failed to update endpoint!"
When I call the URL to set the value1 it seems to work as don't get any http error but the meter is not updated. No event is created.
Could someone have a look ?
Gael
Same problem here. Tried to edit a virtual meter when the message pops up "Failed to update endpoint". The changes seem to be saved nevertheless.
In rules, when I try to put the virtual meter in a "meter" puzzle, it says "no attributes", when in fact there are several measuring-items.
Same issue here. Impossible to modify a Virtual meter/sensor/thermometer. Message is also "Failed to update endpoint".
Seems to be solved now. Thanks!
You might still have issues with new (maybe even old) virtual meters unless its normal that the API is removed:
Create virtual meter and look at the URL in the configuration TAB and you will have something like:
https://my.zipato.com/zipato-web/remoting/attribute/set?serial=xxxxxxxxxxxxxxxxx&ep=b5xxx302-48e4-4xx8-adea-7bc0d5aca5ff&apiKey=a58xxbd7-4080-4ab7-8c5c-87xxx00xxx46&value1=
Refresh your console session and go back to the URL in configuration TAB and see:
https://my.zipato.com/zipato-web/remoting/attribute/set?serial=0xxxxxxxxx1F267&ep=602dd1a8-5863-498b-bxx3-1d029cxxxxx86&value1=
API is gone,is this normal??
I found out since i was creating a new virtual meter for the Zipato plugin for XBMC and need an API key for that to send values to this meter
