How to set the battery value of a virtual sensor?
Guest shared this question 12 years ago
How can I set the battery value of a virtual sensor?
Maarten
Replies (6)
Ehh, why?
Can you rephrase the question? ;)
Why do you wanna set battery level of a virtual sensor? It doesn't have any virtual battery ;)
I'm testing DASH7 with zipato so I have temperature sensors, humidity sensors etc, relay actuators etc in a 433 Mhz Dash7 system. The gateway is connected to a raspberry pi, its will transfer the sensor data (temp, humidity, battery etc) to the zipato system. But currently I cannot replicate the whole sensor.
Dash7 has the advantage that is has a low power listening which makes it possible to have a response within e.g. 2 seconds with a very low cost on battery life. Which has some serious benefits e.g. with actuators (heating etc)
More info can be found on http://www.slideshare.net/MaartenWeyn1/dash7-alliance-protocol-technical-presentation
Fixed with Virtual meter to set battery a value name
Hi Maarten,
I want to try to connect to a DASH7 rasperry how can I do?
What I takes? and what protocol do you recommend for the transmission of data?
I already have the CC430 http://www.ti.com/tool/em430f5137rf900.
Thanks.
Domenico.
currently I have a python script on the raspberry pi which uses the zipato api.
for the CC430 I use the OSS-7 open source stack for DASH7 (in development): https://github.com/CoSys-Lab/dash7-ap-open-source-stack
