aeon Labs multisensor configuration setting issue
on the aeon Labs multisensor configuration tab the values can not be modified/ saved due to a bug in the wakeup field. I want to have the sensor go back to no motion state sooner then it is doing now
aeon labs multi...
Try the reaply device descriptors button (at device settings).
If it's not working you have to delete the device and re-add it
Greetings,
Please open a ticket at http://support.zipato.com, i will handle your problem from there.
Greetings,
When this config issue is planned to repair? It is persistent problem for example for Aeon and TKBhome multisensors. Or must everybody create own ticket for this?
