fgrm222 in rules
charriernicolas shared this question 12 years ago
Hello
One question, how to use the FGRM-222 in a rule to close or to open roller shutter?
I made this rules, but nothing happens.
/wGEpjHt13Cn7wAAAABJRU5ErkJggg==
Thanks for helping.
Did you test by triggering this HTTP sensor by using the url for active and passive. So make it active and then make it inactive using that url.
This rule looks a bit weird for as far as i can see.
You say: -When HTTP sensor for the SUN is inactive do-If button for Roller Shutter is ANY-Roller Shutter CloseCant you just say:-When Sun not active do -Roller Shutter CloseFor as far as i know it will now only change with status of that HTTP sensor changes from Active -> InactiveMaybe an Idea to say -When HTTP Solei ANY-doIF HTTP Soleil activedoxxxxElse doxxxx
OK for the change, it's better, thanks for that
The principal question was an Roller Shutter that does not move up or down. Even if if force in the rule 0% or 100%
