Sorting of lists in panels
SaintNick shared this idea 12 years ago
Issue: Most if not all of the lists (both main and selection drop-downs) in most of the panels are not sorted, and also the sort order is arbitrary and so it is different every session, making it very hard to find the desired item.
Workaround: none known
Fix: sort the selection lists logically, i.e. alphabetically when the listitem titels are alphanumeric, numerical when the items are numeric.
Suddenly the main lists in the panels are sorted, mostly.
But the dropdown select lists remain unsorted. And also in the Android app.
Not for me... "Lights & Power" as still unsorted, can you check please ?
Indeed, now it's unsorted again. Sigh.
