Requete http
Hello, I need to command a scene on my home center (fibaro) from zipabox. I created a simple rule with a virtual module and an http request, but it does not work ... Used URL: http://login:password@192.168.0.xx/api/sceneControl?id=xx&action=start
A syntax problem?
It should work but is That The URL to access hc2? I think the question belongs to there forum. I use many local http requests wo any problems.
This request works. But no on my zipabox.
Look at attach files.
Did you try the post method?
hello. same problem for me. impssible to control my ipx800 with http. fontionne only without login and without password
hello,
do you have a solution to work with the IPX800 in Zipabox?
hello,
