How to use siren (in alarm widget) when it's hidden from dashboard?
thomasfr shared this question 12 years ago
Hello
I am looking for a way to use my siren in the alarm widget, but I don't want it to appear on the dashboard.
There should be a easy way to hide it from dashboard and still be able to select it in alarm widget and rule creator.
Actually, when I select hidden in the siren properties, it disappears from dashboard AND I cannot use it in rule creator/alarm widget.Please allow to use it even when hidden.
I suppose that if it is possible to do it with siren, we then should be able to use any endpoint in rule creator even if it is hidden from dahsboard.
Thanks in advance for considering this.
Great idea. But you can use the hidden devices in the rule creator. First put it in a rule then hide it.
Don't know if this works in the alarm panel.
But we should have 4 options:
- Hide on Dashboard
- Hide on App
- Hide on Rule creator/alarm panel
- Hide All (hides everywhere)
It doesn't work for alarm panel, when device is hidden, it is not selected (and displayed) anymore.
+1 for the different hiding options!
